Get A Way Driver
Get-A-Way Driver The Get A Way Driver is an innovative tool that can stand alone or support a variety of other tools. It also benefits from being convenient enough to store or be carried almost anywhere, including a key chain
Jaws
n/a
Handles/Frame
Single stainless steel handle with molded plastic frame that holds 4 standard 1/4" hexagonal bits and an LED flashlight. The steel frame also incorporates a loop that can be hooked on a carabiner (included) or directly on a key chain or other tie down. There is also a removable bottle opener bolted to the frame. The steel and plastic components also come together to hold a bit driver end that accepts standard 1/4" bits, but also serves as an adaptor for the smaller hexagonal slot found on the Zilla-Tool Jr.
Blades and Tools
The body contains 2x Phillips bits and 2x slotted or flathead bits. All four bits have a black coating and a ball to lock them into place.
Locking Mechanism
n/a
Other Features
Wrench cutouts in the bottom fit oxygen bottles and two sizes of hex bolts.
Sheath
n/a
Dimensions
Length= 96mm (3-3/4")
Height= 20mm (3/4")
Thickness= 19mm (3/4")
Weight= 50.0g (1.7oz)
Variations
In 2009 a new Torx bit version will be available, and the black plastic body will be replaced by a blue body to differentiate the two models. Other than color and bit types, there are expected to be no differences in the two models.
History
Announced at the 2007 Shot Show, released shortly afterwards.
Not yet released Torx version, also related to Zilla-Tool Jr as it's bit adapter is designed to fit in the smaller hexagonal slot.
More Info
Created by Defender. Last Modification: Thursday 21 of April, 2016 22:47:15 CEST by sLaughterMed.
