Jaws
- The jaws of the E4 are spring loaded electrician wire strippers with different gauges on them.
Handles/Frame
- Stainless steel frame with aluminum anodized scales on the handles.
Blades and Tools
420HC BladeBottle Opener
Wire Cutters
Extra-small Screwdriver
Phillips Screwdriver
Small Screwdriver
Spring-action Wire Strippers (20GA, 18GA, 16GA, 14GA, & 12GA)
Wood/Metal File
Tweezers
Spring-action Needlenose Pliers
Blade Characteristics
- All the tools are polished, the knife blade has a chisel grind. Instead of a 2D Phillips the E4 actually comes with a small 3D Phillips driver.
Locking Mechanism
- None.
Sheath
- The Squirt sheath is more of a sleeve type sheath that come in black and grey.
Dimensions
- Length open = 4 inch/10.2 cm
- Length closed = 2.25 in | 5.75 cm
- Width closed = 0.75 inch/1.9 cm
- Thickness = 0.38 inch/1 cm
- Weight = 2 oz | 57 g
Versions
- None.
Variations
The Squirt E4 came in a variety of colors in it's 7 year production. There were grey, red and blue. There is also a Radio Shack version that they specifically had branded that doesn't have E4 printed on it (this version was manufactured prior to it being called the E4).Background
- Introduce in 2003. Made in the USA. Discontinued in 2010.
Related Tools
- The E4 has a few related tools, there is the Squirt P4 and Squirt S4 that both came out at the same time then there are the upgraded replacements for them the Squirt ES4 and the Squirt PS4. The Micra is first keychain tool Leatherman came out with so you can definitely call them related. The Style PS, Style CS and the Style are all similar to the Squirt line as well. They also have a very similar yet smaller handle/frame like the Juice series. The file is very similar to the Mini-Tool and Crunch.
More Info
- Squirt P4/S4/E4 owners club - in the Multitool.org forums
- Squirt E4 Review at Multitool.org
- Squirt E4 at Leatherman Website
