Squirt PS4
Squirt PS4.jpg The Squirt PS4 is another keychain style tool in the Leatherman lineup. It has pliers as the base for the frame and also adds a pair of scissors as one of it's tool. This tool and the Squirt ES4 replaced the Squirt P4, Squirt E4 and the Squirt S4 back in 2010.
Jaws
  • The jaws of the PS4 have needlenose/regular pliers and a wire cutter with no hard wire notch and are spring loaded.
Handles/Frame
  • Stainless steel frame with aluminum anodized scales on the handles.
Blades and Tools
Spring-action Needlenose Pliers
Spring-action Regular Pliers
Spring-action Wire Cutters
420HC Knife
Spring-action Scissors
Flat/Phillips Screwdriver
Bottle Opener
Wood/Metal File
Medium Screwdriver
Blade Characteristics
  • All the tools are polished, the knife blade has a chisel grind.
Locking Mechanism
  • None.
Sheath
  • The Squirt sheath is more of a sleeve type sheath that come in black and grey.
Dimensions
  • Length open = 4 inch/10.2 cm
  • Length closed = 2.25 in | 5.75 cm
  • Width closed = 0.75 inch/1.9 cm
  • Thickness = 0.38 inch/1 cm
  • Weight = 2 oz | 57 g
Versions
  • Early versions of this tool until July 2010 (the first run) came out with torx screws but later versions of it came out with rivets.
Variations
  • The PS4 comes in blue, red and black.
Background
  • Introduced in 2010. Made in the USA. Still in production.
More Info
Created by Poncho65. Last Modification: Sunday 08 of May, 2016 06:49:46 CEST by Poncho65.
