Introduced in 2018 concurrent with the Wave Plus the Charge Plus TTI and Charge Plus were a minor update on their predecessors. Aside from adding a Plus to the name, the changes consist of an updated plier head, similar to the 2014 Surge, which added a crimper under the plier head and user replaceable 154cm wire cutters. All other tools remain the same for the TTI. The Charge Plus updates the Charge AL and also adds the guthook atop the serrated blade from the TTI
The sheath was updated to a premium nylon with a metal snap vs the previous Velcro for closure
Jaws
Newly designed pliers that includes removable and replaceable 154-cm wirecutters, as well as electrical crimpers under the plier head.
Handles/Frame
- Charge TTI Plus has Titanium scales, The design carries over from the previous generation Charge TTI.
- The Charge Plus has black 6061-T6 Hard-Anodized Aluminum Scales, The handles are similar to the Charge AL but do not include the stainless insets.
- G10 Models are a fiberglass material
For all models, the frames folded steel, covered by the scales
Blades and Tools
Both Have:
Outside Accessible:
- 420HC Serrated sheepsfoot blade with One Hand open feature
- Gut hook
- Metal/wood file with a diamond file on the reverse and a metal saw on the lower spine
- Push/pull saw
- Lanyard ring in the saw pocket
Inside tools:
- Electrical crimper under plier head - NEW
- Large bit holder with a #2 Phillips and 3/16 flat-head
- Can opener w/ wire stripper
- Large flat-head screwdriver
- Scissors
- Small bit holder with eyeglass Phillips and flat-head
Charge Plus has :
- 154CM Plain edge drop point Knife
- S30V Plain edge drop point Knife
- Cap crimper in plier face
Other features
- Optional removable pocket clip/quick release lanyard loop that utilize the rocker lock system.
- Ingenious mechanism that locks the knife blades while the pliers are deployed.
- 8"/19cm ruler on the inside handles
Blade Characteristics
Charge Plus has :
Locking Mechanism
Features liner locks on all outside accessible tools, rocker locks on all inside tools.
Sheath
Premium Nylon sheath with metal snap closure.
Heritage Plus includes a classic leather sheath
Dimensions
- Length open = 6.25 in | 15.87 cm
- Length closed = 4 in | 10 cm
- Width closed = 1.2 in | 3.0 cm
- Thickness = 0.76 in | 1.9 cm
- Weight = Charge plus 8.3 oz | 235 g Charge TTI Plus 8.89 oz | 252 g Unable to locate the G10 weight.
Versions
Standard and Heritage (plus only)
Variations
- Charge TTI plus
- Charge Plus G10 (s30v blade) in Earth, Red and Orange
- Black Oxide Charge plus
- Stainless Charge Plus
- Heritage Charge Plus
- Charge Plus FOREST CAMO
- Charge Plus Woodland Camo
- Tom Sach's Nasa Charge plus
Background
Building on the previous generations, this minor update changes the pliers head to add the replaceable wire cutters. And an electrical crimper
Related Tools
- Wave Plus
- Surge
- Charge TTI
- Charge AL
More Info
URL FOR MULTITOOL.ORG FORUM DISCUSSION
%] - in the Multitool.org forums
TOOL NAME
Review at Multitool.org
