Red Devil Painters Multitool
Red Devil Painters Multitool The Painter's Multitool was produced for Red Devil in the USA by Bear & Sons Cutlery. As a matter of fact, the tool uses the same handles and shear jaws as Bear's 157SM Bird Shears model. One notable improvement on the Red Devil tool is its notched jaw. As far as we know, this is the only mainstream multitool produced specifically for painters.
Fully open, with shear lock disengaged
Scraper Blades
Jaws
  • Jaws are heavy duty shears. Much stronger than ordinary scissors.
  • Spring loaded.
  • A tab locks the jaws closed when not in use.
  • Brushed stainless finish.
  • One jaw is notched, making it more suitable to cut small sticks and soft wire.
Handles/Frame
Handles are folded sheet metal. The sheet metal itself is noticably thicker than that of any other plier multitool. Pivot screws are torx drive.
The RED DEVIL logo is stamped into one handle, USA into the other. One side of the tool is stamped with an inch scale, the other side in metric.
Finish is polished stainless.
Blades and Tools
  • Blunt scraper blade, with blunt radiused cutout
  • Sharp scraper blade, with sharp radiused cutout
  • Pry bar, with nail puller slot
  • Can opener
  • Medium screwdriver
Locking Mechanism
The tool blades do not lock, but there is a locking tab that keeps the spring loaded shears closed.
Other Features
None.
Sheath
Sheath is woven nylon with a velcro closure. A leather backing with cross loops allows for both vertical and horizontal carry.
Dimensions
  • Length open = 8" (203mm)
  • Length closed = 4-1/2" (114mm)
  • Width closed = 1-3/8" (34mm)
  • Thickness = 11/16" (18mm)
  • Weight = 6.9 oz (196g)
Background
Produced by Bear Cutlery, and made in the USA.
More Info
None.
Created by Bob. Last Modification: Tuesday 12 of April, 2016 18:36:40 CEST by sLaughterMed.
