History: Par Aide Superintendent Tool
Preview of version: 2
Paul Chen Multi Tool
Plugin execution pending approval
This plugin was recently added or modified. Until an editor of the site validates the parameters, execution will not be possible.
Jaws
  • Multi Tasker jaws are tight enough to cut paper, yet built strongly enough to handle more demanding cutting jobs like cardstock, plastic blister pack material, and thin sheet metal.
  • There is also a wire cutter notch located in near the pivot.
  • Jaws are spring loaded.
  • Using the patented Gerber system of sliding jaws, simply depress the two buttons on the handles and the jaws slide out and lock into position.
  • Finish on the jaws is black oxide.
Handles/Frame
Each handle is comprised of stainless steel sheet bent into an S shape. This allows the tool to have both outside-opening and inside-opening blades.
The word PROFESSIONAL is etched into one handle. Finish is highly polished stainless steel.
Blades and Tools
plier tool
removeable file
back side
low angle
  • Small folding pliers, spring loaded. 3" long (75mm)
  • Plain edge knife blade, with:
    • Drop point profile
    • Outside opening (able to be used without extending the pliers)
    • Thumb stud for one-hand opening
    • Liner lock
    • Measures 2-1/2" long (65mm)
  • Combination can opener/small flathead screwdriver
  • Combination bottle opener/medium flathead screwdriver
  • Three-sided file blade (removeable)
  • Saw blade
  • Phillips screwdriver with square shank
Locking Mechanism
Only the knife blade locks open, utilizing a standard liner lock.
Other Features
A sturdy belt clip is mounted onto one side.
Sheath
None.
Dimensions
  • Length open= 6-1/2" (165mm)
  • Length closed = 4-3/4" (120mm)
  • Width closed = 1-3/8" (34mm)
  • Thickness = 7/8" (22mm)
  • Weight = 8.9 oz (251g)
Made in Dalian China. Originally imported by Fiskars as the Excalibur Multi-Snip.
Variations
The Excalibur tool differs from the Paul Chen only in the markings etched on the handles, and the finish on the small folding plier tool. (Paul Chen = black pliers, Excalibur = zinc plated pliers)
More Info
History
Advanced
Information Version
Thu 05 of May, 2016 19:03 CEST sLaughterMed from 129.115.195.75 new code, TOC, moved pics 7
View
Fri 08 of Apr, 2016 23:11 CEST sLaughterMed from 24.155.119.232 formatting 6
View
Wed 09 of Apr, 2008 03:22 CEST Bob from 71.13.236.214 5
View
Sat 05 of Apr, 2008 22:13 CEST Bob from 71.13.236.214 4
View
Sat 05 of Apr, 2008 21:51 CEST Bob from 71.13.236.214 3
View
Sat 05 of Apr, 2008 21:24 CEST Bob from 71.13.236.214 2
View
