Method
Method Based on the successful Suspension platform, the Gerber Method differs only in the style and geometry of its cast aluminum handles. Introduced in 2007 with three other stablemates (see Related Tools below) the Method is remarkable only in its similarities to the others.
Method
Method
Jaws
Plier jaws on the Method are spring loaded. They come together and contact each other properly out at the tips. There are fine serrations near the nose, a gripping area below that, and a wire cutter area near the pivot.
Somewhat unusual is the fact that the wire cutters are anvil type, as opposed to the more common bypass type wire cutters on multitools.
Handles/Frame
Each handle on the Method is formed from two halves of cast aluminum. (The use of aluminum makes the Method noticable lighter than the Suspension, with its cast steel handles.) The METHOD logo is cast into one side, with GERBER cast into the other.
The handles are painted black, then the raised portions are given a brushed finish.
Due to a surprising number of spacers between individual knife blades, handles on the Method are quite thick, a trait some users find undesirable.
Blades and Tools
All blades are outside opening, all blades lock open.
  • plain edge knife blade with thumb stud for one-hand access. Wharnecliffe profile, 2" long (51mm)
  • medium flathead screwdriver
  • flat phillips screwdriver
  • saw blade, with a rather short 2" stroke
  • serrated edge knife blade with thumb stud for one-hand access. Sheepsfoot profile, 2" long (51mm)
  • combination can opener/cap lifter device
  • small flathead screwdriver
  • fold-out lanyard attachment
  • spring loaded scissors
Locking Mechanism
All of the blades and tools lock open securely. Lock release is accomplished by knurled metal slider switches along the sides of both handles.
Other Features
Tabbed washers (a Gerber standard) are located between each blade, preventing blade "clumping."
Sheath
Molded/woven nylon construction, with velcro closure. Straps on the back allow for both vertical and horizontal carry.
Dimensions
  • Length open= 6" (152mm)
  • Length closed = 3-7/8" (100mm)
  • Width closed = 1-7/8" (48mm)
  • Thickness = 7/8" (22mm)
  • Weight = 7.8 oz (219g)
Variations
None.
History
Introduced in 2007. Manufactured in China.
Other than having different handle styles, the Method is virtually identical to the Gerber Suspension, Crux, Resolve, and Tread.
In 2008 the Evo and Ripstop were added to this list.
More Info
Created by Bob. Last Modification: Friday 15 of April, 2016 04:53:44 CEST by sLaughterMed.
